window lifter switch
    hi guys , could someone enlighten me as how to remove the window switch , the rocker works downward but not upwards , and i think there is crud in the switch, and i dont want to do more damage , which i am prone to do , bricklaying good, mechanics electrics not so good ,
    happy new year to you all ,
    andy
    andy
    You lift the wood panel (coin tray) by the ash tray at the ash tray edge with a small hooked tool, that will revile the screws that hold the panel that they are fitted in, you can then just pop them up from underneath
      thank you milo , that was quick , all the best ,
      andy
        Of course, what Ian has said is exactly right, however you can, sometimes, get away with just levering them up, as they are just a push fit. Use something to protect the wood veneer though.
          thanks for the replies , the last thing i did last night on the car was to spray some wd on the rocker switches ,this morning i tried the switches before trying to prise them out and they worked, i now have windows that go up and down , another step forward ,
          thanks again ,and a happy new year ,
          andy
