I have my servo apart and I also picked up a spare a while back. The Lockheed sevice book says the push rod setting should be .125 for a tandem master cylinder, thats the distance the rod sticks out past the top of the servo or vacuum shell. When I removed mine from the car it was not at that setting. I used the spare servo push rod and made the adjustment its now at the lowest setting with no more adjustment left and it is still a little higher than it should be but it is shorter than the one that came out. I have no reason to believe that the servo that came with the car has been changed or that the push rod has been adjusted, (no tooling marks on the stem) For now I am going to go with the smallest setting I can get on the servo push rod which is about .075 thou above spec and see if i can get my brake system working with servo assist anyone have any comments or have been up this road before?
The reason for the change is my brakes started playing up and it was the concensus that the diaphragm was shot.
cheers Stuart
cheers Stuart
Martin.
