Hi Guys, greetings from the frozen North.  I am starting to rebuild my  cylinder heads after a skim/valve grind and would like some advice  please.  The tappet clearances on one head (LH) are within tolerances  but on the other head 5 clearances (4 inlet 1 exhaust) are below  minimum.  My question is, should I try to get all clearances the same,  either Max, Min, or middle, or should I just be happy that they are  within tolerance.
Peter, Cupar
					Peter, Cupar
