Hi all
Had a full professional engine rebuild back in 2006 but unfortunately not had much time on the road since then...only 500 miles or so added. Heads have been retorqued by the specialist per post run-in
Last started a year or so back then the battery failed. New batttery arrived yesterday, now engine fires but will not continue to run unless I keep the starter motor turning which I realise will only cause damage..... After a burst of life, which fills u with hope the engine just dies, and will do so continually each time cranked. Not convinced all cylinders are firing.
Carbs were also rebuilt and are getting fuel.... spark is good.
Engine ran fine last time used .... ideas re what may be the cause after a long period of inactivity.... or best order for process of elimination would be gratefully received...thanks in advance
RayR
RayR
