As above.
I would like to know how your gearbox is mounted onto the crossmember (is it the stock Stag item) and which bushes it uses. Do they look anything like the stock Stag gearbox mounts, but bolted into a different part of the crossmember.
Stock items look like this on the BW35 and MOD cars:
Dimensions AFAIK of these mounts off the car is L:38mm, W (in the waist): 39mm with the studs being 5/16" UNF.
If you have pictures that would be an even greater help.
Final thing is are your propshaft flange angles coherant on both ends, or is a CV jointed prop used. As a final question, what is the length of your prop on the car and is it of the sliding variety?
Many thanks. Fear not, the bombardment of questions will stop one day
