Having fitted refurbed carbs, I had a sticking needle valve which led to overflow and dump of fuel.
Had been advised that stopping the power to the pump using the fuel cut off manually will obviously stop the flow of fuel to the carbs, and with the car running will empty the float bowls on the carbs.
Went to check that the fuel cut off was working and low and behold it had been bypassed electrically. I had never taken much notice of it previously and deffo had never taken the time to make sure it was wired up and operational.
Luckily I contacted local SOC member ( Alan, Inverurie ) who explained how to get into this, clean it, and connect it back up. Luckily, although corroded inside it was not beyond repair, and after strip down and clean up it seems to be working as it should.
This now got me thinking , just how many other Stags have these bypassed/disconnected, and taking into consideration the fuel cut off is a safety device to avoid a fire if involved in an accident, it may be worth letting others know so they can check their own ones.
Not sure, but assume that this may have been covered before, anyway there will be newer members who are unaware of this particular component, and what it should do, if they had a shunt.
Only posted this in the interests of safety, as it was obviously originally fitted for a reason.
Have attached pics if at all interested.
