Percentage of Anti-freeze
    Hi Everyone,
    I'm sure that this has been brought up in the past, but I couldn't find a previous post on the site.
    So sorry if that's the case.
    My question is what proportion of anti-freeze should I use when I drain the system?
    I've seen 25% mentioned as the correct ratio to stop it freezing up, but I seem to remember that 50% was mentioned somewhere for anti-corrosion reasons.
    What's the panel think?
    Thanks,
    Frank
    Get 6 pints in and you wont be going far wrong Frank.
    Mark
      30-35% is fine. Too much actually has a detrimental effect on cooling as anti-freeze doesn't have the same ability to cool as water does. This level is fine to prevent freezing in our weather conditions and sufficient to deter corrosion. As nib says, 6 pints (3.5-litres) is good.
        I'd be inclined towards 50%.
        Thats the figure recomended by most car manufacturers today, also pretty sure i've 50% reccomended on tony hart site
          Originally posted by Frank G View Post
          .. I couldn't find a previous post on the site.....
          There's loads of info if you want to trawl through it! Try this one for a starter:
          Type 'anti freeze' into the search box, press the magnifying glass symbol, and hey presto!
          Biggest anti-freeze concern is the colour.
            Hi Frank.
            I use a mixture of 1 ltr of anti freeze to 2 ltrs of water, (33%) I drive my car everyday in all types of weather also been to Norway in the winter. Have had no problems with the cooling system.
            The one thing I do is every year is flush the system out and put in a fresh mixture.
            Hope this helps.
            Cheers.
            Paul.
              I use a 50/50 ratio mix, primarily to limit corrosion. Never had cooling problems so far, even befopre the pump was refurbed
                Another user of a 50/50 mix. It is just so easy to remember..........
                  Use deionised water if you live in a "hard water area" prevent furring up of your water ways..
                  Adrian
