A good afternoon in the garage
    Made good progress with the rear end today
    The diff / rear subframe went up relatively easily with three jacks; trailing arms, springs, shocks and prop re-fitted, new handbrake cable.
    Tomorrow's list :-
    brakes to connect & bleed, driveshafts to re-grease and fit new boots, then the exhaust, not fogetting the trailing arm bolts when she's back on her wheels....
    Looking forward to driving her this year
    Looking good Dave there has been a lot of Stag activity around northants today, good luck for tomorrow,
    P,s like the yellow touches.
    Adrian.
      Many thanks to IanI today, brakes bled, driveshafts & exhaust back on and back on her wheels;
      Having also drained the gearbox to do the sump gasket, re-filled with Comma AQF, however needed to add another 1/2 litre after warming up the engine. I then took the car for a short test drive, all ok apart from 1st/2nd gear seem noisy, certainly much noisier than before; fluid level is ok but need to check when it's really warmed up? Hoping it improves after a longer run.
        Nice job Dave hope your gears sort themselves out..
        Adrian
          Between you two, and me getting my old girl back we're in for a busy summer, I hope. Nicely done guys ! ! Martin.
