Hi guys,
having now started to clean out the bores I'm faced with a dilemma. The bores all measured up superbly in all directions as being within original works tolerances (just!). I'd planned to reuse the original pistons as I've been cautioned against County pistons and rings.
On three cylinders I'Ve now uncovered some surface pitting. It looks hasty, in reality if you run your finger or fingernail over it you don't actualy feel any height difference, it just feels, err, matt. I presume this has come from water in a standing engine - to be honest, the pitting looks less like corrosion and more like casting porosity!
None of the bores have any other damage or scoring.
So, now I know it's not perfect and Ross Brawn wouldn't give it the nod, I need to work out a practical way forward and need some sentiments from the experienced engine chaps - flying farmer & Co (!).
Am I faced with:
a) waste of time reassembling it. Rings will disintegrate at the first turn of the key. You need a rebore and County oversized
b) if you're willing to accept that it won't last forever, and that it will be a bit of an oil burner, then put it back together and plan for an overhaul in a year or two.
c) nothing to worry too much about. Get a honing tool and run it up and down the bores. Castings were never perfect anyway.
I actually have acquired already 4 x original oversize Triumph Stag pistons and am hoping that another four might turn up sometime in the next couple of years, so would love to go along the b) route unless one of you Gurus says a) is unavoidable.
Cheers for any advice chaps.
Drew
Photos: As usual, anything like this on a photo looks like Mount Everest and is accentuated to the extreme, but the affected areas are shown quite well. The pitted areas are local, but the flash makes the whole bore look messy. Best representation is the last metal coloured photo. Third photo is a "reference" undamaged bore.
DSC00048 (Custom).JPGDSC00050 (Custom).JPGDSC00051 (Custom).JPGDSC00053 (Custom).JPG
Am I faced with:
Drew
