Has anyone got any photos of Triumph 6 cylinder engine conversions showing engine mounts used in there Stags. Did they use 2000 style mounts or TR 6/ Vitesse type. Please e mail photos/ info to dave-jell@supanet.com all help gratefully excepted. Dave.
Triumph 6 Cyl Engine Conversions Info Wanted.
The engine mounts on the 2000 range fit to a crossmember which in turn is bolted to the chassis legs. I'm pretty sure that the holes (3 each side) exist in the Stag chassis leg. In this case, the 2000 style cross member should bolt straight on!
Remember that there are 2 type of cross member - with and without the ARB mountings.
Mike.Mine since 1987. Finished a 20+ year rebuild in 2012. One of many Triumphs and a 1949 LandRover!
Dave, I took a 6 out of my Stag recently but the x member is still fitted. The attached might help, especially the second one. It bolts on instead of the anti roll bar but not quite in the same holes. 015.jpg018.jpg. I dont need that x-member any more if you want one.
Mike if you're anywhere near Henley it would be good to get together for a pint sometime.
PaulPaul - 3 projects, 1 breaker - garage built and housing 2 white Stags. One runs, one doesn't
Thanks to you both for your info this is the type of fitting I used many years ago using the engine / crossmember from a t.2500s and keeping the anti roll bar. I would like to use the exsisting mounts on the body thus using the side mounts on the engine as tr6/vitesse. anyone any info on this please or photos. Thanks Dave
