At last its done and dusted, i fitted a new water pump today. the joy no water in the vee, no anti freeze smell.
The job went very well considering i didn't really know what i was doing, things of note were .. the water pump that i removed was a 12 vane pump...boll..ks... my replacement pump is a 6 vane, my engine number said it should be a 6 vane, luckily whoever fitted the 12 vane pump used a 6 vane cover, that was lucky.
The bush in the engine block, i had to well and truly muller that to get it out, the new bush did not want to go in so i persuaded it with a bit of wood and a hammer...of course you have to make sure its square ... i think you know where i am going with this, after some filing it looked a bit like a bush.
The water pump contrary to popular belief does not just drop in, it needs some persuading with worryingly and increasingly bigger hammers, very nerve racking but eventually it went down far enough so the bolt cleared the cover.
The water pump gaskets were sealed with holybluestuff but on torquing up to 20lb the gaskets split, good job i bought a double set, forget the torque wrench, used a ratchet instead, best guess probably around 19.5 lb!!
Scratched the car wing with my fly zip, the wing cover blew up and i didn't notice, about an hours tcut to put it right, then my dad thought he would see if he could knock down a brick wall with a stag door, you cant, result chipped paint, i touched it up then took off glasses, cant see it.
And thats it job done thinking of starting up a stag water pump fitting company.
All gaskets were sealed with holybluestuff, new bolts were fitted to the inlet manifold, all nuts and bolts had copper slip applied, the servo copper washers were annealed .
I will be placing a few pictures of the days events on my profile page later for anyone that's interested.
A big thank you for the people who helped me to get this job done ...Steve
