Ground clearance
    Ground clearance
    Does someone know, or could someone kindly measure for the ground clearance at the front and back of unladen Stag around the valances? The ROM gives 4" ground clearance 4 up, but I am guessing this measurement is going to be around the sills.
    A trolley I made for for my car to be transported for dipping has been determined by the transporter to be too high to be carried safely, so I need to drop/change it. As I know my car didn't scrape the floor or the ramp of a transporter on normal ride height, I figure if I get it trolleyed to that height again, not only will it go up and down without damage but the transporter will be happier too.
    Baz
    Mine is about 14" at the back and 11" at the front, hope that helps.
      Thank you.
