I'm refurbishing a 1977 stag, manual overdrive with a ropey gearbox, I'm replacing the gearbox, prop shaft and rear differential, with a 2010 3 series BMW six speed gear box, prop shaft and differential, has anybody else done this? what problems might I run in to?
BMW 6 speed gear box??
Interesting ,how far have you got?whats the fit of the main shaft of the gearbox into the crank bush like?do you think you will have to machine the end of the shaft or machine the bronze bush?I'm thinking of changing the MOD box for something else but haven't decided what to try.I already have E30 rear end which works well.Keep us up to date when you get it working .
Cheers Steve
I spoke to the late Adie Turner about the 6 speed box. He basically said that 6 forward gears was unnecessary with a V8, that 6 gears was more for engines with narrow power bands and economy.
Saying that, if one could be found with an appropriate gear set i would consider it!
MikeMike.
I'm just starting with it, I have all the parts and components, and have worked out what i need to do, i need to modify the bush, also remove 3 inched of the bell housing from the BMW gear box, using the original starter motor and fly wheel, which needs to be drilled and tapped using the BMW clutch assembly. the only thing i haven't worked out is the speedo drive.
Originally posted by TitainiumKitkat View PostI'm just starting with it, I have all the parts and components, and have worked out what i need to do, i need to modify the bush, also remove 3 inched of the bell housing from the BMW gear box, using the original starter motor and fly wheel, which needs to be drilled and tapped using the BMW clutch assembly. the only thing i haven't worked out is the speedo drive.
Cheers Steve
Originally posted by Kevin Garrod View PostIsn't the standard MOD box effectively 6 gears?
