I need to identify the following parts and find where to order from, I am new to this so not sure of the correct techniclal terms but will try to describe and upload photos. I belive they all come from the inner ball joint at the top of the tie rod arm. They are nylon ball joint washer, One locking nut washer 6 small spacer washers (Ithink thats what they are) and a small spring. all found under the nut situaited under a black gaiter at top end of tie rod arm. Thanks in advance.
