Hi all,
I have just done a coolant flush. I flushed the radiator, and then removed the N/S engine block plug as it was the easiest to access. The coolant ran out clean, no crud. I then attached the hose to a length of plastic tube that I fed through into block plug hole and gave it a good high pressure blast until you could drink what came back out. Because I did this I didn't bother with the O/S block plug, as I assume they both lead into common waterways and I'm assuming the pressure of water I managed to get into the N/S one will have cleaned them all out sufficiently. Is this assumption correct?
Bob
Bob
