Forum I have a problem minor by stag standards but an irritation none the less. every few weeks the overdrive fuse blows, annoying as I can see no obvious shorting out or dodgy connector. I have replaced the switch in the gear lever with a new one and replaced the wire leading to it, underneath the trim where it connects to the loom. are there any other areas where an intermittent short is likely or a solenoid on the way out might it cause a problem?.
Advice would be welcome as would better weather on a Sunday what a horrible day weather has now cleared but so has my inclination for a top down run at 3 degrees in the Normally Warm South.
Peter
