Can anyone recommend an alternative to the Lumenition system that is straightforward to fit?
Electronic ignition alternative to Lumenition system?
The low budget Accuspark/Powerspark types are easy to fit inside the dissy. Peter at LD Part Sells a similar one too but includes new base plate. I havent tried the Pertronix, but they look easy to fit and the Ignitor II is claimed to be a high spec one, comes with a higher price too. I think some of our members have the Aldon/Pertronix.Last edited by V Mad; 13 March 2012, 18:24.
Originally posted by Richard Saunders View PostPlease help the clueless...Which Pertronix model/product do I need? '73 MOD - Ignitor 1, 2 or 3?
I havent had an opportunity to test the Aldon systems as yet. Hoping to do a report at a later stage.
Originally posted by Richard Saunders View PostThanks Chris. I have my fingers crossed that my problem is a new coil. The fuel pump was knackered but having replaced it I still have a problem...
Regarding your question, it has pretty much been answered. I have used an Accuspark type system on my MGB (it was made by BritPart) with no issues. The 123 ignition is another way, but that is pretty much an entire new distributor and ££££.Last edited by ChasR; 13 March 2012, 19:37.
Aldon/Pertronix Ignitors come at a lower-cost when ordered from retrorockets (http://www.vintageperformance.com/retrorockets/) - check your US$ exchange rate - they are sent from within the UK so no customs extras to worry about
........ Andy
I don't believe that points are too bad (they were fine on most of my old cars) as long as two provisions are met. That is the setting up of them (a dwell meter does help alot there (or at least I found it to) in comparison to setting it up via feeler gauges) in addition to the quality of the parts. The parts for me are the bugbear, with a number of condensers failing prematurely. With the Stag's P&C setup not being the cheapest around (but not the priciest either comparatively speaking) it is easy to see why Hall effect electronic systems (like the Accuspark et. al) are considered.
I don't normally get this kind of luck, but it turns out my knackered coil/knackered electronic ignition problem turned out to be just a poor connection way up behind the dashboard. Famous last words, but everything running fine now!
If anyone needs the services of an automotive electrician in the Reading and surrounding area I have found a real gem. An older chap who has worked on just about everything with wheels and no doubt a great many things without them as well. Just PM me and I'll happily pass on his details.
