Hi guys. Remember me, georgestag1 of the stuck stu stub in the cyl' block. The stellite drill method was a waste of money and time (still nothing ventured nothing gained) I managed to remove the stub using a rotary cutter. It took a lot of time and effort resulting in a not quite round hole to which I fitted a helicoil. The heads are now fitted
However all isn't plain sailing and I have the following problem. I managed to cast the right hand timing chain which ended up near the sump. (I won't say how) (The left hand chain is still in position) I can refit the RH chain but as the camshafts aren't fitted I fear I've lost the timing.
My Haynes manual isn't a lot of help as it only caters for an engine out of the car. For timing it states "check that the line on the flywheel is aligned with the line marked on the flywheel housing". That's no help to me with the engine in situ.
I think I can retrieve the situation as follows. The section in my haynes manual re fitting the jackshaft states "Position the jackshaft so that the line marked on the sprocket slopes slightly down towards the lefthand bank with the dowel to the lefthand bank and the No2 piston on TDC". The jackshaft and left hand chain haven't been removed. Am I correct in thinking the timing can be retrieved by referring to the marks on the jackshaft sprocket ?
I look forward with bated breath too helpful comments re the above.
My best regards to all my "helpers"
George stag1
George stag1
