a friend of mine has got a problem with his wipers will not turn off with switch. will stop eventualy. the switch has been changed but has not made any difference has anybody any ideas
wiper problem
Originally posted by kbstag View Posta friend of mine has got a problem with his wipers will not turn off with switch. will stop eventualy. the switch has been changed but has not made any difference has anybody any ideas
the parking switch on the windscreen wiper motor, is bad contact or broke
dave
If the failure happened suddenly, It's quite possible that the tag that operates the park switch has broken off, which means a new rack, or some surgical welding, if gradually, it's likely the slipper has worn, or the screws underneath, holding the switch housing are loose and the whole thing has moved. None of this is difficult or expensive.Martin.
