Hi,
Having a few issues with an exchange steering rack which I would appreciate some help with.
The mounting feet either side of the rack are not level. They are at least 5degrees to 10degrees out and when the new rack is in position on the front cross member mount it does not sit flat. Is this an assembly fault or can this be corrected in the mounts. I suspect the former.
I have centralised the new rack and I've noticed that the flat section of the control valve pinion shaft (i.e location for pinch bolt connecting intermediate shaft) is 180degrees opposite to that of the original rack. Is this another assembly issue? I suspect getting the pinch bolt back in might be more difficult but otherwise probably acceptable.
Very new to Stags, owed a TR6 for 29 years so not used to all these mod cons!
Any help much appreciated.
