Well, I am very pleased to say that the short engine and gearbox are now reunited with the body! It was an interesting experience lifting them both in together, but it does work and there is sufficient space to get the engine between the chassis rails. I fitted the engine mounts to the block after I had lifted it all up, but I reckon there was space for one of them to fit through already on the engine.
However, I'm not convinced that I have the gearbox cross member the correct way round. It was a bit of a struggle to get the 'hanging studs' to align. So, all you experts out there, can you tell me if this is the right way round?
In the following picture you can see the new rubber mounts under a bit of strain, and quite how the speedo cable will get past the cross member is anybody's guess as the fitting is right behind it!
Sorry for all the cobwebs. It's been some time since I've been under there. They'll soon blow away when it gets back on the road....
I really feel it's now beginning to happen. Today's work was probably the hardest bit to do. The next job is to finish cleaning and then painting the front suspension cross member and then refit it with its new rack bushes.
Thanks!
Thanks!
