Finished all the rear poly bushing, fitted my brand new second hand eBay half shaft (bargain) ready today to take the old girl out in the sun. Noticed a drop of water on the garage floor underneath the bottom hose so there I was underneath poking around with a screw driver trying to tighten up the jubilee clip. I couldn't understand why I couldn't do it up any more and the drip was still dripping. Get impatient as you do I got hold of the bottom hose and gave it a tug. Now bear in mind we are talking about a two month old re cored rad. Whoosh there i was covered in coolant I was soaked. Oh yes the jubilee clip was tightened up just fine, the monkey that had assembled my rad obviously forgot to solder the bottom pipe on. At least it didnt happened miles from home and overheat my engine!!!
Can't believe it!
Ruddy hell thought them sought of things only happened to me.I had the clutch master cylinder fail in the same place (quarter of a mile returning home from a run out.The second time I had no gears and had to start it in gear and change up carefully into second nursing it home at 4000 rpm at 27mph
.All sorted now.Good luck with yours.
Si
