Getting The Stag ready for 01/04 tax - hard top off, soft top up and appears to have shrunk; fasten at the front or rear and there is no way it will close - probably a simple answer to this (a good soaking maybe??) but thought I would ask anyway - It has not been used for some 3-4 years and is new, never been wet and once upon a time closed fine.
Shrunk soft top
Try loosening the rear rail retaining bolt as far out as it will go and try slamming the rail down until it catches. If successfull, leave the hood up for a while to stretch then repeat the action gradually tightening the bolt up.
Perhaps that may help.
John.Your wife is right, size matters. 3.9RV8
I had the same problem with my car when I bought it last June. The previous owner couldn't even remember the last time the hood was up.
I tried fiddling about with the rear slam bolt and the frame adjusting bolts but nothing seemed to make the hood fit any better. It would fit, but under a great deal of fiddling and force
Salvation came when I left the car out overnight in heavy rain. Almost by magic within 24 hours the hood went from seeming too small to being too big. Then I had to adjust the frame again
So the moral is to wait for the current dry spell to end, leave the car out in the rain, and try the following day.
PeterBereft of a Triumph of any description.
My Stag had a very slack hood when I got it, but I made the mistake of hosing all the dust off the hood when I was respraying the car, then leaving it to dry in the house.
I now have a drum tight hood that I can sometimes only close by opening the bonnet, climbing on the bulkhead, and sitting on the front rail while reaching in to work the catches. Too embarassing to do in public, so I normally resort to catching the front, but leaving the rear catch undone, at least it keeps the rain out. I am hoping that it will eventually stretch again, but after a winter with the hard top on I am expecting a struggle next week!
NeilNeil
I have the same issue. My rear catch seems impossible to go in, even after a heavy spell of rain and fiddling with the rear rail. Taking the hard top off will be fun!
Originally posted by flying farmer View PostMy Stag had a very slack hood when I got it, but I made the mistake of hosing all the dust off the hood when I was respraying the car, then leaving it to dry in the house.
