Right, so i was on here a long time ago but my old account seems to have died, therefore i'm back with a fresh account.
We've just finished reassembling our Stag after replacing the clutch to find the hydraulics of the clutch master/slave arn't working. They were working fine when it was last driven (August) however at that time the clutch slipped on every hill so the car was laid up to have its clutch replaced.
The old clutch was extremely worn (looked possibly original) so it definately needed replacement. We did not disturb the hydraulic side of the clutch release mechanism since we didn't need too therefore we can't understand why it won't work.
The symptons are:
-the clutch pedal moves freely and springs back up, but doesn't feel like its doing anything (which it isn't)
-the slave cylinder (replaced about 6 years ago) is pretty much at its full extent, it can easily be pushed back in with the rod that attaches to the clutch release arm however it will slowly push itself back out again without us doing anything
-most importantly pushing on the clutch pedal does not create any movement at the clutch slave end
We have bled the hydraulics, no bubbles came out and there was no difference, theres plenty of fluid up in the reservoir.
The clutch release arm moves freely on the gearbox, you can hear the release bearing touch the clutch pressure plate at one extent and then hear the 'clunk' when its back out the way.
So thats it really, we're thinking that the clutch master has possibly died but before we go shopping for a new one some experienced advice would be much appreciated
Thanks,
Mat.
The symptons are:
Thanks,
Mat.
