After an hour or two in the garage this afternoon, I've now concluded that the float in the front bowl of my Holley is not shutting off the fuel supply at all whih is the cause of my rich running. When I lifted the nut off on top of the bowl the float adjustment was already screwed most of the way in and the fuel kept pouring out of the sight hole on the side so no more adjustment available-probably bottomed out by PO.
Th question is has anyone changed the floats on a Holley or is it possible to just adjust the tab that is supposed to shut off the valve? I've had a look on YouTube for some videos and the initial process of removing the bowl looks easy but I haven't found any video on changing the float. Any advice gratefully received. Hope Real Steel are open tomorrow.
Paul
Paul
