Sealing door window frames to door
    Apart from the various interior and exterior window trims, which I've already got fitted, what is the best way to seal up the gaps round the leading edge of the window frame where it enters the door at the hinge end of the door ? Dum dum ?
    1977 Tahiti Blue Mk II, my late Dad's car. sigpic
    Hi Richard, I'd go with DumDum, at the back edge as well. Martin.
      Thanks Martin. I guess it's a relief at least to be getting to that stage !
        Yeah. Let us all know where you buy your tin of Dum Dum from!
          Dum Dum is ok for small gaps.
          Sometimes the gaps are too big for just dum dum so a piece of black foam rubber helps.
          2.
            http://www.cliffordsbrighton.com/ind..._897_1113_1118
            They show 3 available. I'd buy them if I were you. I heard that Dum Dum ceased manufacture about 2 years ago and remaining cans are (apparently) being sold under the counter. Forums worldwide are trying to track down the remaining tins and even eBay doesn't turn them up anymore.
            Paddocks and LB restorations had some tins a couple of months ago.
              Gosh - I didn't realise I was sitting on an investment !
              I have two tins (which I'm afraid I do need !) and haven't a clue where they came from ! It was ages ago.
                I wish I knew, I seem to recall walking past some at Stoneleigh
                  Apparently 3M Strip Caulk is the stuff to use instead of Dum Dum, or so t'interweb tells me!
                    Dum Dum is available off the shelf at my local motor factors. Never had a problem buying it.
                      You might be onto a gravy train there Mike - buy the stock and sell to these lost souls!
                      http://www.pistonheads.com/gassing/topic.asp?h=0&f=140&t=1131277&nmt=
                      http://www.morrisminorspares.net/shop_item.php?ID=3723
                      hi to all does any one know where i can find to buy dumdum or a replacement for dumdum with the same properties since i think they stopped producing it? thaks
                      Originally posted by Stuart
                      DumDum doesn't set on the surface any more - they have changed it. The surface remains sticky, catching dirt etc, and it smudges if you run over it with a cloth. So it is no longer the right stuff to use for the panel to body joints.
                      Cheers, Paul
                      You have obviously bought a tin from the last batch they made. I have talked to the makers and this is the problem that they have found since trying to come up with an alternative ingredient to the original that was HSE`d off the market. Thats why they have now stopped making it. You need stock that is about three years old or older.
                      Stuart.
                        Ooh might have to call in when next passing...
                        Just my luck it is no longer available now and they have sold out in the last few months or so.
                        It's one of those substances that when you need some, nothing else can really do.
