Can anyone tell me how to check the static ignition timing on a car with the Lumenition fitted?
I have seen the diagran in the technical book where you connect a lamp from the +ve terminal to the negative lead on the distributor but I have 4 leads on the negative terminal two white black long leads, one white black short lead and a purple which is from the Lumenition I guess.
Thanks in advance
Thanks in advance
