Before we get a sunny day and I can start on overhauling the front struts, I notice that the Repair Operations Manual (ROM) states that I don't need to apply the spring compressors until I have removed the units from the car and before I remove the cotter pin and slotted nut which all seems reasonable to me. However, the Haynes Manual says I need to apply the spring compressors before doing anything else - ie, while the strut is still mounted to the car.
Also, the Haynes Manual says about refitting "Refit road wheel and when positioned in the straight ahead position, grasp the road spring and rotate it so as to bring its lower extremity directly inboard" (whatever that means) "This is to ensure that the spring bows out slightly when loaded so preventing fouling on the wheel arch". However, there is no mention of this in the ROM.
Can anybody confirm that I should ignore the Haynes Manual and stick with the ROM?
Also, both Manuals say I will need some Plastiseal - does anyone know where I can obtain this in a small quantity?
Simon
Simon
Martin.
