Hi All
There are occasional horror stories of waterpumps and jackshafts seizing etc resulting in severe and expensive engine damage. Please excuse my ignorance on this particular area of a Stag but if the original pump is replaced by an external belt driven or electric one, does that completely remove the jackshaft issue? Am I right in thinking that the original pump is driven off the jackshaft which in turn is powered off the distributor shaft? If the original pump is removed does the jackshaft remains in place doing nothing other than spinning round with no load on it?
Sorry to be asking what is probably a load of stupid questions but I just want to get in clear in my head what benefit an external pump would give me.
Bruce
Bruce
. I also made the mistake once of taking the bottom pulley off then timing the engine on one of the cams before replacing cams and chains. ok so whats the problem with that? Due to a knackered bottom sprocket (overtightened chains?) the chain had slipped a cog and I retimed it all out of place.......it ran ok and no damage but just felt sluggish.
