Ferd - I might join you, maybe we could get one brilliant car out of two...
Started to look at second engine rebuild after first rebuild expired when jackshaftseized due to disintegrating waterpump gears after 1800 miles. Block has been repaired and looks good so time to look at the heads - could see a couple of Z shaped valves in LH head but cam turned ok.
Stripped valves out, nr 3 had cracked guide, then noticed condition of combustion chambers -the first one (ie nr 2)looked different to the other 3 ( I have scraped the carbon at the top)- is this head gasket failure? I've never had one before - and the heads were skimmed and rechecked before fitting.
Then tried cam in head without valves to make sure seizure hadn't dried up the oil supply. It had a couple of tight spots but turned - narrowed it down to nr 4 cap. Tried RH cam safe affect. I did remove the dowels and studs for refacing but all seeded ok on assembly Adjacent valves 6 & 7 had strangely peeling carbon on back so may have been like it on first rebuild - any ideas why or what to look for?
Not sure I can look my wallet in the eye if I have to visit the machine shop again - this engine has cost mea fortune in last 12 months, I still love the car butRover V8's are starting to wink at me as I pass the scrapyards.
Paul
Paul
