Change the oil or not ?
    I have just found out that my stag has been filled with synthetic 10-40 oil prior to me purchasing it. I am nearly ready to put it back on the road and I'm wondering if I should leave this oil in or change it for a 20-50, and if so what type.
    20-50 Mineral, Valvoline VR1 is pretty good, most on this forum have it.
    Sukh.
    P.s Eurocarparts have an offer for it.
      When I got my Stag a couple of months ago I had no idea what oil was in there (PO didn't know-it was his late father's car). On the drive home oil pressure was around 20. One of the first things I did was change the oil to VR1, now the oil pressure is 40. That may help you make your decision - for £30 inc filter and 15 minutes work I think its a no brainer.
      Paul
        Hi Steve, 10/40 is too thin for an engine from this era, aside from anything else, it drains away from the camshaft buckets, and you wind up starting with a dry top end, 20/50 leaves a pool of oil which does it's thing when you start. Valvoline VR1 sport 20/50 is about as good as it gets. No, I'm not on commission Martin.
          Thanks guys
          20-50 it is .
          Any problems just draining the synthetic on refilling with VR1 ?
            None whatsoever. Sooner the better too....change the filter too, as its full of synthetic as well.
              Thanks Kryten
              Off to get the new oil NOW.
                Originally posted by StephenP View Post
                Thanks Kryten
                Change the filter while at it...
