Just replacing chains after rebuilding engine and with the No2 piston at TDC (measuring with DTI and know it to be correct) and cam correctly aligned the cam sprocket mounting holes are out.
The heads have had a light skim which should change this by a small amount and as far as I can see it makes no difference to the alignment which way around either the Camshaft or Crankshaft sprockets are fitted as they are symetrical. Both sets of sprockets are new and could be drilled incorrectly compared to the position of the teeth.
I have the equipment to accurately redrill the sprocket holes to match my timing but I wondered is this a problem everyone faces and do rebuilders accept the cam timing is out by a few degrees?
or do what I am probably doing to do, remove the sprocket and redrill a pair of holes that correct the timing. Alan
