I need some advice before I go mad..
I bought a so say fully reconditioned engine a few months back from a man who tells me he has built lots of Stag engines to a good standard.
Fitted the engine into the car,plumbed it up and filled with water to test for leaks..havent even started it at this point..
Water(lots of) ran down the Vee not even under pressure..It appeared to be coming from the pump overflow.
Took off the manifold, 12 vane pump,6 vane cover also bolts for cover too long.
Ok Ive changed a few of these pumps over the years albeit 20 years ago so fairly competent(I think)
Pump looked pretty new so put it back together,changed the cover and guess what it leaked..
Out again renewed top seal,refitted again and still leaking although not as much..but this is still without any pressure or the engine started..
Can water leak out of the overflow only if the seal that sits under the impeller is the problem.The underside of the impeller is flat and clean and looks newish.
Ive not heard of this but if I run the engine are things likely to settle down (wishful thinking on my part)
I have built Stag engines before although only using new pumps and not dismantling old ones,so am I missing something..is the only way out an LD parts mod..
Help would be appreciated Guys..
