grating gears
    grating gears
    as discussed on previous forum have finally got the new clutch in
    with new crosshaft and bearings release bear carrier and clutch etc
    clutch feel smooth but the gears crunch in first and worse in reverse
    bleed the slave clyinder the master clyinder has new seals and the slave is new
    the pivot pin is the middle position but tried changing position which makes no raal difference
    I note people have spacers on the slave rod will this help
    Did you do the thrust pins on the release fork? If they are flat, you lose a lot of movement - you can buy an adjustable pushrod for the TR6, I think from Revington TR - this may help
      yes changed the pins in the fork along with just about everything else the gears change ok when on road and you can feel the clutch bite but at rest the gears are notchy to go in to asny gear and the reverse gear crunches
      many thanks
      mark
        Did you loosen the slave and spin it around on the pipe when you bled it so the bleed nipple was at the top ,this can stop some air getting trapped and could give you a bit more movement.
        Cheers Steve
          Could be oil drag..... you could try draining the gearbox, and refilling with 20/50..
            put 70-80 ep gearoil in
            the slave clyinder in at the top to aid bleeding
              just a up date I am concerned now that the clutch amy not be correct
              I have used a good local supplier in cambridge .
              took the car out agian today the reverse crunches going in to gear but car does not learch
              the 3 gear grinds sometimes and the gears fell notchy
              the gearbox was drained during the replacement but did not have much oil
              but previous to the clutch renewal the gears were all smooth and id not crunch
              so to sumerise I have changed the internal clutch parts due to it sticking and found numerous
              faults so changed just about everything with new
              the ggearbox now has new seals so holds oil filled with ep 80 gearbox oil
              and the clutch feels good but grates as discribed above
              real do not want to re do the gear box again with out tryign every thinG
              tHE OVERDRIVE NOW ALSO WHINES WHICH IT DID NOT BEFORE SO DO WE AGREE THE FIRST THING TO DO IS THE
              OIL TO 20 -50
              ANY ASSITANCE PLEASE THANK YOU
