Gents (and Ladies!?)
I am trying to find out further information or more clarification in which is the correct way to wire in a coil to my 1976 MK II Triumph Stag with original 3.0L V8 engine. The car has very recently had a complete overhaul/restoration and a new Lumenition Optronic ignition system replaced (supplied as kit from Rimmer Bros). The car had been running with no issues and has barely covered 1,100 miles. The car broke down during a days driving last month with no immediate indication anything was wrong, engine simply died when approach traffic lights.
After investigation and trouble shooting it was identified that the 1st 12V Lumenition coil had failed. I purchased a new Lumenition MS4 12V coil, again from Rimmer Bros last week, and the car is back up and running. The Ballast resistor installed with new coil can be seen with one black wire attached on bottom side, top side of BR is marked +.
My concern however is the very short life span of original coil that did not have an apparent Ballast Resistor. This new MS4 coil clearly states (Must be used with Ballast Resistor, supplied). The instructions given with new coil are really not clear to me at all and I remain concerned the new coil may also fail prematurely.
I tried searching Lumenition site for further information but they do not list the FK.113 that was installed on my car. There is many conflicting theories on what is best to do!?!? Apparently the MK I Stag used a 6V coil with BR, the MKII Stag has a Ballast Resistor incorporated into wiring loom (Nichrome or Constantan?) It is a new wiring loom installed on my car.
As you can see from the pictures attached there is two joined wires (White/Yellow + White/Pink) on a single connector attached to + side of Coil, there is also the Red wire from the Lumention Module attached to + side of coil. On the - side of coil is the White/Grey wire and Violet wire from Lumenition module.
If i do have to wire in the Ballast Resistor can you please describe how to or supply wiring schematic. Would I have to install additional jumper wires or reconnect existing ones?
Any assistance would be much appreciated.
 Lumenition Optronic Ignition, 12V MS4 Coil - How to wire in Ballast Resistor.
