If you are planning to buy front strut gaiters (138748) SOCTFL recommends members to inspect the available parts as follows before purchase: -
• It should be possible to stretch the gaiter from its “at rest” length of about seven inches to its “fully extended” length of about ten inches by hand, and without using excessive force. If this isn’t possible, e.g. the bellows are too shallow or the rubber appears “rigid” rather than flexible, the part will soon tear itself apart whilst in service.
• During expansion and compression in service the air trapped inside the gaiter is vented in and out. Look for two neatly punched round holes at both top and bottom. Irregular jagged holes or slits are unacceptable as these constitute stress points from which splits may radiate.
