whats this please?
    whats this please?
    Hi all, got a hose set from LD today, in it there is a plastic washer about 1" in diameter with lobes on the inside, have taken off all the hoses ready to fit the new ones and not found anything similar, can somebody tell me what its for please? its image 2 on ld web site under part no grh001k
    thanks derek
    Hi Derek, its the washer that goes on the brass radiator filler plug. Simples
      Sounds like the sealing washer to go under the brass filler plug on the top of the rad.
        Thanks all, mine had a fibre washer on it, but its been replaced with an elbow as i have a header tank fitted
        derek
          mine has a copper washer on it
            There is a land rover brass filler plug that can be used as an alternative.... it has a semi captive o-ring instead of the plastic washer you mention.
            The early version was slotted across, current version cast - in and short slot
            I think this is correct part number:- ERR4686 mostly around £2 on ebay
