Additive for noisy differential
    Hi, Can anyone recommend an additive for a noisy differential.
    Colin
    Snake oil or shredded Nylon tights.
    Sorry could not help it
      Hi Colin, sadly no, the old boys used to put Fullers Earth (clay) in, that silenced them for a bit, but accelerated wear. Martin.
        Wasn't Moly Slip mentioned once?
        Mark
          Mark
          Brilliant stuff, but it won't help with the noise. Martin.
            Mark
            Yes, I put some in my noisy diff a couple of years ago. The noise came back not long after.
              Sawdust or my wife's gravy or custard
                Colin
                Lots of money, hard work and bruised knuckles.......
                  Colin
                  I put some Wynns in mine it's for leaky and noisy diffs. It didn't cue it but definitely made an improvement so I guess I would recommend it. I did change the oil as well.
                    I use Penrite EP85 - 140 oil in mine which did have the effect of quietening it slightly and also slowed the leak I have a little. It has bought me a little time but a diff rebuild will still be needed. May be worth a go...
                      cash!
                        Turn the volume up on the stereo until you can afford to change it
                          My diff became noisy on a round trip to the Isle of Wight last Spring. Glad I took it apart straight away as one of the bearings was disintegrating rapidly, at least I got away with a bearing set rather than needing a crownwheel and pinion which the rapidly accumulating swarf would have destroyed in no time
