Putting the doors back together last night, window motor works fine, finally sussed out how the door handle / lock should go, but when shutting the door it did not go in far enough, the door still needs to go another 6mm. It latched and unlatch fine, I could push into the correct position [ in line with the body work ].
I tried to adjust the striking plate on the b-post and the latch on the door, but the door is still sticking out. The gaps around the door are good, the swage line is good, the door is not sagging, all hinge bolts are tight. Am I missing something? without the striking plate on I can hold the door in place, it would make driving a bit difficult though! Got the MOT pre-booked for end of May.
Any suggestions please.
