Hi, Had a blonde moment. Decided to use the Stag to pop to work at the weekend to give it a run and forgot that it was nearly empty and I didn't have my wallet either. Never mind when the clicking fuel pump told me I was about to run out I thought never mind put in the 5 litres from container in the boot. On the way back strange noises from the engine loss of power and then it ground to a halt. It would restart with the choke out but wasn't happy and eventually gave up. The very helpful AA man checked decided since I had checked there was fuel going to carbs and plenty of spark that the fuel I had put in was stale (very possible it was pretty old) but even though we pumped out the old fuel and put some new in no joy. Car now back in my garage. Anybody any ideas of the best way forward?
Stale Fuel?
This topic is closed.
things you should do. plugs out and clean,set and dry them,check fuel filter is not full of crud,plenty of fresh fuel and give it a whiz. things you may have to do. plugs out and get them hot on gas stove,refit whilst still hot (wear gloves) carb elbows off and tip a little extra fuel down the carb throats to keep it running if necessary (had to do this on mine) be patient it will live again it's just paying you back for giving it crap fuel !
Pete.c
I mentioned on here about fuel going off a while ago and several people said it doesn't happen, but I've had it and seen it several times - maybe it's different makes (cheap supermarket fuel ?) that suffer.
Anyway, I reckon stale fuel could well have been your initial problem but, to me, even more telling was your clicking pump which says that you've reached the dregs. So, as Pete's said, you'll have picked up crud and I reckon cleaning that out thoroughly, from EVERYWHERE could be your answer - change the filter, clean out the float bowls etc etc.
Good luck
(Not really
Sorry was that a bit strong) seriously though I've had dead fuel a non starter for no reason changed the fuel fired up stright away. Graham
