Hope you can help,on the Bristol stag clubs eventful trip to Ireland i.e. one stag caught fire another's brakes seized on.Mine started to run hotter (did not boil) and started loosing water.
Its just been diagnosed with head gasket failure.
The garage have sent the heads off to be checked,they say they are ok but should be skimmed.Before I bought the stag in 2003 the engine was rebuilt and the heads skimmed ,the garage would like to know if anyone knows of any measurement i.e. from the head face to a fixed part on the head so they can check if there is enough metal left to be skimmed again,also when it was rebuilt 2003 it was fitted with std head gaskets,so am I correct in saying that if they fit the thicker head gasket and they don't take off more that 0.55mm we would be ok,but would like any measurements just to be sure
Malcolm
Malcolm
