HI all, I'm getting water in both front footwells, not a lot, but enough to wet the carpets, I've tried various things to no avail. All I can say positively is that it's not the windscreen. Does anybody have experience of curing this ? Martin.
Wet !
Originally posted by martin View PostThanks guys ( except Roger) No smell of anti-freeze, and it only happens when it rains. Martin.
I know you have disagreed with me in the past Martin but I also got wet carpets when it rained,BUT ever since I have welded and filled the seams between the front wings and panel below the windscreen, it has never happened. I had to prop up the carpets regularly to dry out, now I don't.
It now appears to divert the rain water down along the wing and to the front. Another problem was water getting in through grommet holes in the bulkhead which has also stopped.
Test it out with a hose or watering can whilst sitting inside with a torch to 'trace' any leaks from under the dash.
Good luck.
Jeff.I only do what the voices in my wife’s head tell me to do!
Originally posted by martin View PostGood thinking Jeff, thank you. No corrosion involved thank God.Martin.
PS. I thought you disagreed with me ?
Forgot to state the obvious, start at the bottom and work your way up, ooooerrr
