Today I .................
    Today I repaired sealed and painted the fuel tank, wonder what other repair task will crop up when I fit it next week?
    That look's Ace mate, are you sure it's not a new one
      Cheers, you have made my day......
        Looks really good!
        what did you use to seal it with?
          Originally posted by Ian Durrant View Post
          Looks really good!
          Hi, Used the Rustbuster Slosh kit...prior to that repaired a couple of pinprick holes at the bottom with Araldite "90 seconds" and when dried fibre glassed it for good measures.
          Sukh
            looks fab Sukh, you've inspired me to do mine now, i have new carpets to fit so might as well take the tank out and repaint it, well done what have you painted it with?
              The usual rub down first then used Halfrauds Etch primer on the bare metal areas followed by grey primer, then used gloss black aerosol left over from spraying my servo.
              P.s. Well worth using the Rustbusters Slosh kit since you are going to have the tank off, "they" say the coating help against the new fuel amongst other things.
              Forgot to add, Rustbusters advise/recommend putting some sharp stones in the tank when cleaning it out with their fluids....Well I had a hell of a time trying to get them OUT!..in the end I had a brain wave and used some BBQ thongs to good effect.
              If you do use stones make sure they are not small ones ( if you want to use).
                Sukh.
                Is that some form of eastern perversion??
                John.
                  If so, please let us in on the exact methodology.........
                    Didn't know B & Q sold thongs, I get mine from M & S.
                      You bunch of perverts! find your own! .....but here they are anyway, Red is best but pink will suffice.
                        That looks nice, the wife says my mankini is getting a bit threadbare in places.
                          Thanks Sukh, i have just added another job to the list
