Struggling with wheel balance
and needing new rubber, I'm planning to spend some hard earned reddies on 15" Minilite wheels with +15mm offset from Midland Wheels; before going ahead I wanted to understand offsets, tyre sizes and how they may affect clearances.
Current - 185/80 R14 on standard 5.5J alloys ET32.
New - 195/65 R15 on 5.5J Minilites ET15 would give about 12mm extra clearance from the front suspension but would be about 22mm nearer the wheel arches.
After some head scratching
I've come up with the following diagram which would suggest there should be no problem (if my understanding is correct ???) and looking at the current clearances there should be no problem with the extra width, especially as the slightly smaller overall diameter with the 195/65s would help with rear wheel arch clearance and I'm not worried about a small difference in speedo reading.
Not sure though about front inner wheel arch when on full lock; any thoughts
