From what I've seen the best solution to fitting these seems to be to work in the metal fabrication industry, given that I don't I was wondering if anyone had any drawings of the brackets they have made that I could proudly copy?
No drawings Ian but as a starting point i can tell you that I used 12mm x 30mm ali strip down the inner tunnel side and the front fixing bolt goes through the seat fixing hole into the original captive nut the rear fixing is helicoiled into the ali strip and the rear of the ali stript is fixeds down into the other captive nut.NB you have to remove the extra piece bolted to the seat runner on the fiat seat.Front seats 002.jpgFront seats 024.jpg
Thanks, I looked at your pictures and that was really what I wanted the drawings of, I'll get hold of some ali strip and I'm sure I can sort something out with some local assistance.
