Evening All
Has anybody got any good advice as to the easiest way of removing and refitting the right hand combination switch on the steering column? I have removed the shroud and unscrewed the swicthes at the top. The wiring harnesses are routed behind the metal plate that sits along the underneath of the column. Do I really need to remove all that and the column clamp just to change the switch? :shock:
Just to complicate things the immobiliser/alarm system is involved with the indicator switch wiring
Bruce
Bruce
