Toe in or toe out?
    Toe in or toe out?
    Is this too much toe in or toe out, I can't remember which is which?
    Can't see your toes.....
    Out
      [ATTACH=CONFIG]16553[/ATTACH]
      You got home safely then, get them bl**dy bushes changed as so as!!!!
      Great day Al, let me know about the wheel bearings
        Only happened after a err... 'slightly spirited' drive around Brands. No pace car today
        It caused my track control arm bushes to disintegrate!
        Was an interesting drive home....
          No pace car, I didn't know that! - Who was today's pace setter - he/she certainly had a lot of self restraint!!!
            Self restraint and Al, that's an oxymoron!!
            Glad you got home OK. You will be much happier with tight bushes.
            BTW it's negative camber not toe in/out.
            John.
              Indeed that is camber, pretty excessive by the looks of things (although I believe in certain car cultures it is the 'in' thing ).
              Some new track control arm bushes should see you straight .
                I took a peek underneath - it didn't look like there was a bush at all on the drivers side!
                  Is that Hollywood suspension?
                    You go round peeking at peoples bushes? Wouldn't have thought that of you Dave!!
                      and thanks Al for the ride around the circuit, not sure I would have been quite so relaxed if I had seen your the angle of your front wheels before the drive!
                      - Alan
                      PS for one who is so accomplished in removing trees the odd bush will be a doddle!
                        - Alan
                        They were alright before the Brands lap. I blame it on the extra weight in the car! lol
                          Will do Ian - poly's this time though. And I will be in touch re the bearing.
                          Cheers...Al
                          p.s my son is 17 in a couple of weeks, do you think he should drive round Brands next year??
                            Al, I dunno about toe in, its more like TOW IN.
