A or J type overdrive unit
    Hi all,
    Anyone know the difference between an 'A' type and 'J' type overdrive unit?
    Not sure if the pictures help.
    The Stag is a 1973 (January 8th) Mk II ? with manual gearbox and original 3.0L engine.
    Hi Lofty.
    You have an A type overdive.
    Coppo.
      Originally posted by Coppo View Post
      Hi Lofty.
      Coppo.
      Coppo,
      Hi Can you tell me how to spot the difference?
      Mine is a 71 MK1 mod,but had reconditioned gearbox
      Thanks Mark
        Originally posted by maverick View Post
        Coppo,
        Thanks Mark
        Different castings and solenoid. See pictures for help:
        A Type:
        J Type:
        Neither of these are on Stag gearboxes, but they will help identify what you have.
          Mine's a J type and it's not the same as yours.
          Jtype has a finned bottom plate.
            Coppo,
            Thanks Mark
            Cheers Steve
              Coppo,
              Thanks Mark
              Hi Mark.
              The soleniods are an easy spot... A type is at an angle, J type is straight......
              A easy way is the sumps where the filters are, A type is a round brass cover, J type is a rectangled cover.
              Hope this helps.
              Coppo.
                Everything you want to know about Overdrives is here:http://www.buckeyetriumphs.org/technical/technical.htm
                Although this site is primarily for TRs, quite a bit of the info, including Overdrives, is equally applicable to Stags.
                  As I recall from overdrives past the A type engages with more of a satisfying surge but if trying to change gear with it engaged (3-4) it crunches. The J type doesn't crunch. But I've also got a LH type in my MGB so I could be mistaken.
                  Nick
                  Nick
                    'Tis true - the 'A' type keeps the oil pressure up all the time and then diverts it to the operating pistons when wanted - hence a faster engagement. The 'J' type keeps no pressure and only builds it up when wanted - hence slightly slower engagement. It also sometimes seems to have a delayed dis-engagement too, I guess for the same reason.
                    'J' type has a slightly higher ratio too....
                      Can i cross-fit a J type on a Stag formerly equipped with a A-Type or is there much adaption work needed?
                        Different main shaft in the gearbox. So it either requires the equivalent 'box or a rebuild.
