A sticky question
    A sticky question
    What is the recommended / tried & tested adhesive type for attaching the 'TRIUMPH' badge to the front bumper plinth ?
    Search of the forum didn't turn up an answer, they're not expensive I know so I could take my chances but I don't want it coming off when warm nor melt the plastic
    Hi Paul, they're self adhesive and it's pretty good, I wouldn't bother adding anything. Martin.
      Thanks Martin, I feel very silly now for not realising that
        Not silly at all mate, only special nutters know everything Martin.
          That will be me then
            I've just (like last weekend) fitted new ones front and back. 2 things I would comment on, be very careful with the alignment and try to remove the remains of the old glue first. I didn't do the latter well enough and the new badges don't sit perfectly flat. They are much thinner than the originals but still look Ok and I don't think they'll come off in a hurry.
              Paul - don't listen to Martin. You have to lick the back of the badge
                Don't I also need to lick the plinth to ensure a good bond ?
                Old badges off last night, all glue residue removed & plinth degreased - but could I locate the new badges - DOH !
                  That depends entirely on how much you've had to drink ! No booze, no sticky Martin.
                    That's exactly why I took a good slug of Makers Mark before setting about my degreasing of the plinth by tongue
                    Now off to find some 9V batteries to test . . .
                      why test some batteries try chewing some tin foil same result
