Non Stag problem.
    Non Stag problem.
    Sorry not to do with Stags but there is always help on this forum for which I am truly grateful.
    When any new e mails arrive on my i pad, they tend to delete any that are already there in the inbox.
    I have deleted all 4 e mail addresses and started again with just my main one, now I can send myself a test message from my i pad and it gets received and new ones do not delete the existing, BUT when I send a test e mail from my main computer to myself, it arrives on my main pc but not on the i pad.
    Any ideas please?
    Jeff.
    Jeff,
    This could be any number of issues.
    Although Oz may be different, I will attemp to help but need a bit more info.
    Who do you run your email thru?
    Is it an Exchange account or Pop3?
    What mail app are you using on the iPad? Is the the inbuilt one or Outlook for iPad?
    Check your mail handling settings. It may be set to move or delete emails once they have been read.
    If you can answer the above questions we will be alot closer to solving the issue.
    Regards,
    Robin
      Hello Robin,
      Thanks for helping.
      My e mail is with BT Yahoo.
      Pop 3
      Inbuilt on i pad.
      There are no settings on the i pad to delete as such, only to delete after periods of time, at the moment set to max of 1 month, but there is a setting requesting before deleting (manually I assume).
      Hope this helps.
      Jeff.
        Hi Jeff,
        You mentioned that just running one email address has solved the deleting issue, so lets leave that for now.
        In reard to the other, and again assuming that you have outlook on your pc. Can you tell which version?
        There is a setting in outlook that allows you to leave a copy of emails on the server. If this is not set, your PC will recieve the email or your iPad (whichever one you use first) and it will be deleted off the server and not be available to any other device.
        If you can determine which version of Outlook you have, it would be easier for you to Google "Leave copy on server", than for me to try and expalin from the other side of the world.
        BTW. You would be please to know it's warmer in England than it is here.
          Hello Robin,
          I am running M outlook 2007.
          I have made the setting to leave on the server already.
          Not cold here just bl**dy wet!
          Jeff.
            Jeff,
            This issue seemed really odd so i did some research.
            It would appear that Yahoo having an issue with there servers not pushing email to iPad. Here is one of the forums I checked out, you can see it is frustrating people all over the world. https://discussions.apple.com/thread...t=300&tstart=0
            You mentioned you had other accounts, can you retry one of these and see if you get any results?
              Thanks Robin,
              Glad it's not just me then.
              My e mails are still not being 'pushed' from my pc to i pad if sent from my pc as a test and only a few from outside are filtering through.
              Thanks for your help.
              Jeff.
                Hi Jeff,
                Sorry I couldn't fix it for you.
                Just a thought. I run our company emails through Microsift 365. It is a cloud based system and is good value for money. It will allow access to your emails anywhere and from practically any device. Because it is cloud based, anything you you do on any device is reflected on all the other devices. Maybe the club itself coulkd set up if members were prepared to pay the monthly cost.
                We have 40 licenses here at a cost of AU$7.95 per month each.
                just a thought.
                  Robin,
                  Just double checked the advanced settings and 'leave message on server' was unticked even though I thought I had ticked it, so this should make a difference which was one of the first things you suggested, thanks again.
                  I have had so many problems with BT Yahoo which is why I opened a G mail account and even now I am having trouble with a Yahoo e mail account, all configuration matches the other e mail addresses yet it fails to log on to POP3 server, same problem I had with another which now works fine for some unknown reason.
                  Thanks again.
                  Jeff
                    I've had email problems with by and outlook. Signing out of yahoo then signing back in again usually fixes it but I have to do this 3-4 times a week
                    Phil
                      Phil
                      Thanks Phil,
                      I regularly sign out and even re boot the pc which as we all know rests everything most of the time.
                      Pain in the ass, but there you go, thanks again.
                      Jeff.
                        Hi Guys,
                        It would appear that this is an inherent issue with yahoo. Most "FREE" email providers have some sort of glich in their systems given the amount of different OS out there. i.e. apple android, microsoft, etc etc.
                        The best you can do is to keep trolling thru forums and find the latest "FIX" some geek has come up with.
                        On another note, would anybody have a way of finding out the date my Stag came off the assembly line?? LD43296AK.
                        Regards,
                        Robin
                        p.s. You guys may have faster internet but we have a cricket team.
                          Funny how I get on average, 40 spam e mails a day yet I cannot receive a legitimate one I sent to myself (as a test, not because I have no mates).
                          And so far, I have been awarded/offered about $500 million from different sources, mainly Nigeria strangely enough, even had the FBI send me an e mail this morning.
                          Have not been greedy to take a penny as I would have top pay all that capital gains tax and that would upset me.
                            And as I typed the previous message, this arrived...............
                            Good day,
                            You might be skeptical about this message based on the fact that we have not met before but i believe the lord will give you the strength and understanding to read this message and see reasons with me. My name Mrs. Mary Painter from Italy but I reside in Dorset, England. I am a 65 year old childless widow.
                            Recently my Doctor told me that I would not last for the next 3 months due to my cancer ailment.. Before the death of my Late Husband who was a British citizen, we deposited some money with a Security company here in England and our decision was to donate this fund for the charity purpose, since we do not have a child that will inherit this money. I know that you get a lot of this type of mail everyday. Me too. That was how i got this idea of using this medium to contact you my dear. I want you to be plain and truthful to me for i am to you. The lord sees all things and knows why they occur. I believe in the lord and serve him with all my heart and i will not use his name in vain. I have no better option but to use this medium to contact you. Everything i tell/reveal to you is the truth and nothing but the truth.
                            I want you help me invest this fund on CHARITY in your area. I want it used for the betterment of humanity. As soon as I receive your reply I shall inform my lawyer/security companies to assist you take over the funds from the security firm, which you shall use for the establishment of the charity ventures to the Glory of God almighty. Please my dear. Feel free to tell me anything and open up to me. If you cannot help me, kindly tell me. I know that it is a strange way
                            of asking you for a favor. I am helpless and cannot do this on my own because of my ailment. I need a God fearing person to help me carry out this task for me. I am only being candid with you for i have no time to play games. Take me as a sister and help me if you can. If you know that you have a negative mind about this, do not reply. For anything worth doing is worth doing well. Assure me that you will act as I stated herein.
                            NAME: __________SURNAME:__________________SEX: _____ AGE: ______MARITAL: _______________COUNTRY: CONTACT ADDRESS: ________________________PHONE NO#___________OCCUPATION:_______________
                            Please reply me via email: mrs.marypainter@gmail.com
                            God bless you.
                            Mrs. Mary Painter.
                            Unbelievable!
                              This was the FBI one...........
                              ANTI-TERRORIST AND MONITORY CRIMES DIVISION
                              FBI HEADQUARTERS IN WASHINGTON, D.C.
                              FEDERAL BUREAU OF INVESTIGATION
                              J. EDGAR HOOVER BUILDING 935
                              PENNSYLVANIA AVENUE, NW WASHINGTON
                              D.C. 20535-0001
                              TEL: 202-324-3447
                              Attn: Fund Beneficiary
                              This is an official advice from the FBI, foreign remittance/telegraphic dept. (FRTD), it has come to our notice that the (central bank of Nigeria) C.B.N and there local banks in Nigeria has released your full inheritance/contract payment of 10,000,000 U.S dollars into bank of America in your name as the beneficiary as there corresponding bank in USA. The bank in Africa knowing fully well that they do not have enough facilities to effect this payment from Europe to your account and they used what we know as a secret diplomatic transit payment S.T.D.P to pay this fund through wire transfer.
                              They are still waiting for final confirmation from you on the already transferred funds, to enable them crediting into your account accordingly. secret diplomatic transfer payment are normally funds related to drug/terrorist and money laundry system of payment, why must your payment be made in such secret transfer, if your transaction is legitimate and not related to drug/terrorist and money laundry, why can't the bank in Africa via Europe effect direct transfer into your account than secret diplomatic payment transfer.
                              Due to the increased difficulties and unnecessary scrutiny by the American authorities when funds come from through such payment process from Europe, Africa and middle east, based on the records we had in the past always identified such method of payment as drug/ terrorist/money laundry funds, to avoid problem with the us government as soon as these funds reflect in your account in the U.S.A, it is our mandatory obligations to ascertain the documentation and certification of this funds before the final crediting into your account.
                              We advice you contact us immediately, as the funds have been stopped and held in our custody pending when you were able to provide us with a diplomatic immunity seal of transfer (DIST) and letter of indemnity clearance certificate within 24hours from the united nation international fund monitory unit (UNIFMU) that authorize the transfer and certified that the funds originated from Africa and middle east is free from terrorist/drug and money laundry or we shall confiscate the payment. We will allow the funds to be release into your nominated account immediately you make provision the required document.
                              You will be directed where and how to get the document if it is not in your possession.
                              Your’s sincerely
                              Robert S. Mueller, III
                              FBI Director
